L-11,12 for Version 2.1, and L-15,16 for Version 3.0, minOccurs for Orthogonal Camera and Perspective Camera is removed.
L-16 for Version 2.1, L-21 for Version 3.0, minOccurs for Line is introduced in Version 3.0
L-28 for Version 2.1, L-32 for Version 3.0, "Bitmaps" is the new element introduced in Version 3.0, and Bitmap is moved inside it.
L-54 for Version 3.0, New Element "Aspect Ratio" is introduced in Version 3
L-71 for Version 3.0, Content of FieldofView is edited
L-78 for Version 3.0, Aspect Ratio is introduced
L-101 for Version 3.0, "PositiveDouble" is the new SimpleType introduced
L-94,95 for Version 2.1, L-108,109 for Version 3.0 , "minInclusive" is changed to "minExclusive" value.
L-100 for Version 2.1, "ViewSetupHints" is removed in Version 3.0.
L-107 to L-111 in Version 2.1, is removed in Version 3.0.
L-114,124 in Version 2.1, L-122,133 in Version 3.0, "minOccurs" for Component is added in Version 3.0.
L-127 in Version 3.0 , "ViewSetupHints" is added in ComponentVisibility.
L-129 in Version 2.1, L-138 in Version 3.0, default value is added in Version 3.0 for "DefaultVisibility" .
L-139 to 143 in Version 3.0, "ViewSetupHints" is added here in Version 3.0 .
L-147 in Version 3.0, "minOccurs" is added for the Color element.
L-151 in Version 3.0, "Components" is added in Version 3.0 .
L-138 in Version 2.1, L-159 in Version 3.0, "use" added in Version 3.0 .
L-166,167 in Version 3.0 , type is changed for "OriginatingSystem" and "AuthoringToolId" in Version 3.0 .
L-155 in Version 2.1, L-175 in Version 3.0, pattern is changed in Version 3.0.
L-183 in Version 2.1, L-163 in Version 3.0, pattern is changed in Version 3.0.
L-199 to 213 in Version 3.0, "Bitmap" is added here.
L-182 ,183 in Version 2.1 , L-216,217 in Version 3.0, enum is changed .
L-185 to 188 in Version 2.1 , is not anymore in Version 3.0.
