Blender BIM version
  1. C
    I have installed the new Blender BIM add-on, version 0.0.210731
    I removed the old add-on first, restarted blender and installed the new add-on.
    I made a new very simple IfcProject, then it prompt me to save an IFC file. After I click the export to IFC button in the dialog I get the following console output.
    I tried overwriting an existing IFC file, but the same output.
  2. B
  3. M
    @Coen thanks for the report - yes, as @brunopostle suggests it could be due to a last-minute change. I've reverted it, and replaced the code only for the Windows build. Can you please redownload the latest release from the BlenderBIM Add-on (make sure it is a fresh download), and try again?
    @brunopostle do you mind investigating further and seeing if you can replicate, if it is Windows specific, or affects other platforms?
  4. B
    @Moult I don't have Windows machine to test, on Linux 'IFC export' writes a log file as expected.
    @Coen do you see a similar error importing an IFC file?
  5. C
    @brunopostle I tried importing an IFC file first with the 'old' add-on still installed. It gave this error.
    @Moult
    I downloaded a fresh Windows executable and removed the old add-on. In Windows I need to run Blender with Administrator rights to remove the add-on. I tried making a new simple IFC file and overwriting an existing IFC file.
    Both work. I get this console output.
  6. B
    @Coen just to be clear: you fixed it by uninstalling and reinstalling blenderbim? or you fixed it by downloading blenderbim again and installing this newly downloaded version?
  7. C
    @brunopostle
    I fixed it by installing the newly downloaded version.
  8. R
    Hello, same issue here on Linux...
    Reloading and reinstalling the add-on doesn't solve the issue.
  9. M
    @RLop thanks for the report, I thought it might've been a Windows only version. I've now applied the hotfix to the Linux build. Please redownload the version again from the BlenderBIM.org website and see if that helps.
  10. R
    @Moult yes, thanks, it works !
