by mclare on 4 Sep 2021, edited 23 Oct 2021
I was going to take a stab at building IfcOpenShell from source on a Mac, but just wanted to check if anyone else has done this. On a quick glance, I've already found I'll need to find some alternate sources to build the dependencies (it doesn't look like all of them are on homebrew), so I was just curious if this has been done successfully before.
by Moult on 5 Sep 2021
@mclare you're probably already aware that there are bot builds available for Mac (except for the arm chips) and have other reasons for wanting to build on a mac (contributing, perhaps? :) ) But I thought I'd mention it anyway.
by mclare on 17 Sep 2021, edited 18 Sep 2021
Yep @Moult , I was trying to build for contributing, but ran into a snag at the tail end with my favorite compilation error: undefined symbol for architecture x86_64, which is happening when linking IfcConvert and `IfcGeomServer. I might not have the correct boost libraries installed (I've got whatever's the latest from brew, which is v1.76.0).
I'm stumped on how I need to change the order of the build to get around the errors I'm getting here:
https://github.com/IfcOpenShell/IfcOpenShell/issues/1740
by Moult on 14 Oct 2021
Glad to see this is solved and I apologise I couldn't help.
by StefanBoeykens on 22 Oct 2021
My flow to use IfcOpenShell on Mac:
Update Xcode developer tools
Install Homebrew
brew install cmake
brew install opencascade
Had to install OpenCollada from sources (download/clone, cmake + make + make install). In there, I had to tweak the GeneratedSaxParserUtils.cpp file to find std::isnan properly. Then added the necessary OPENCOLLADA_INCLUDE_DIR and ..._LIBRARY_DIR into my bash/zsh profile. I also had the problem that I temporarily had to remove PCRE during compilation.
brew install icu4c
brew install boost --with-icu4c
Added the ICU bin and sbin folder to my $PATH
brew install pcre
brew install pkgconfig
brew install python3
brew install swig
I also had to force C++11 in de CMAKE instructions.
brew install libxml2
Install JSON for Modern C++ header file (https://github.com/nlohmann/json)
And finally my build string
cmake -DOCC_INCLUDE_DIR=/usr/local/include/opencascade -DOCC_LIBRARY_DIR=/usr/local/lib -DOPENCOLLADA_INCLUDE_DIR=/usr/local/include/opencollada -DOPENCOLLADA_LIBRARY_DIR=/usr/local/lib/opencollada -DBUILD_IFCPYTHON=ON -DJSON_INCLUDE_DIR=/usr/local/include -DGLTF_SUPPORT=ON -DLIBXML2_LIBRARIES=/usr/local/opt/libxml2/lib/libxml2.dylib -DLIBXML2_INCLUDE_DIR=/usr/local/opt/libxml2/include/libxml2 -DIFCXML_SUPPORT=ON -DENABLE_BUILD_OPTIMIZATIONS=1 ../IfcOpenShell/cmake
The rest just takes time
make -j16
sudo make install
make clean
It was more involved when I also wanted the full PythonOCC support. That took some attempts, especially once homebrew updated opencascade beyond the latest supported version known to PythonOCC and removed the previous version completely.
by mclare on 23 Oct 2021
@StefanBoeykens Thanks for the response! I managed to get it up and running with some trial and error using brew, similar to what you did. I would like to use my brew installed gcc compiler instead of XCode’s, but it got too far into the cmake hole to figure out how to manually override the compiler chosen.
