I assume this can be found in BlenderBIM, but how?
If it is based on a wire. Where can the wall thickness be found and changed?
a sample ifc file is attached ...
cheers bernd
cheers bernd
Hello Bernd, Just guessing ti see if i can understand something :)
Wall on line 62 for example has 2 representation. One Is the body and One Is the axis.
The body Is an extrudedareasolid, based on a rectangle that has a thickness of 0.15m. so if you want to change the thickness you should change that parameter at line 49.
The axis Is a 2 point polyline, defined at row 57, and has anything to do with the definition of the body representation and so with the thickness.
I dont see in the file any informations about the material, so the thickness of the Wall seems only to be represented in the Wall body...
Hope i didn't write any wrong thing :)
This is what I know from all my ifc knowledge too. :-)
But I am interested to know how this information could be retrieved and changed in BlenderBIM gui?
The IFC material Type of the IFC wall gives it it's thickness, you can change it from there
where do I find this in Blender BIM? Do you have a screen?
Here is a screenshot ^
And here is a video showing how IFC Object materials are created in BlenderBim:
You can also just load from the IFC library that is available and just edit the wall materials found there
The attached file is just my naming scheme you can download the latest libraries here:
https://github.com/IfcOpenShell/IfcOpenShell/tree/v0.6.0/src/blenderbim/libraries
Which version of BlenderBIM is that?
I'm running 12.09.2021
Normally I'm on the daily build,
but this featureset has been there since 22.05.2021
You can find the latest build here:
https://github.com/IfcOpenShell/IfcOpenShell/releases
download the py39 version of whatever OS you use
Is it possible to roundtrip the thickness of an IfcWall with IfcWallType in BlenderBIM? If not, what's a good way to store a thickness parameter for a wall in IFC?
@Coen the thickness should always be roundtripped :)
My phrasing of the question was a bit unfortunate, let me try again:
Is it possible to drive the width of a IfcWall with a type paramter stored in IFC? Hope I explain myself clear.
@Coen yes, the wall type has a material layer set which parametrically defines the thickness of the wall type. All occurrences of that wall type inherit the material layers, and so also inherit the thickness. Changing the type thickness will change all the occurrences too.
@Moult
Cool :-D, I should look into that
more details mentioned here.
