BB: different IfcExtrudedAreaSolid depths on a common type.
  1. T
    If you have (2) beams, for example, that share the same type, is there a way to change the IfcExtrudedAreaSolid depth of one, without changing the depth of the other?
    vid:
  2. G
    I don't experience the same behaviour, how did you create the beams ?
  3. T
  4. T
    After further investigation, i think it's because that file was exported from Revit and imported into BB. File here
    I tried a clean file, here, and it worked.
    vid:
