Dear OsArch community,
I’m Johan Luttun, a software developer specialized in BIM applications. I’ve always been interested in automating tasks for the AEC industry, as I believe there are still tools missing for a smooth and useful use of information models, at all phases of construction projects and besides it. I’ve worked on a wide variety of software projects, mainly with Thomas Krijnen from AECgeeks, on data validation and geometry.
I’m happy to be in charge of the implementation of the official IfcOpenShell test environment to offer a guarantee regarding the reliability of the IfcOpenShell geometry interpretation functions used by IfcConvert and BlenderBIM.
Objective of the project
The goal of the IfcOpenShell test environment is to provide a trustworthy source regarding the performance of IfcConvert geometric conversions - based on the underlying IfcOpenShell geometry interpretation - and make key metrics of those operations accessible to the users on the web.
To provide some context, we are not starting from a blank page as we already had some scripts in the pipes that now have to be tied together to make a real application out of them. The objective of the project is to reflect accurately and up to date the performance of IfcOpenShell regarding the conversion of IFC files to other geometric formats.
A part of the grant allocated to BlenderBIM by Epic has been dedicated to this project. Thanks to this support, I’ll be able to spend time to create the new scripts, tie them together, deploy the application and progressively implement a nice user interface.
The performance of the file conversion will be measured in terms of errors and processing times. The motive is to be able to answer the following questions after a new commit is made on IfcOpenShell:
Does this commit make the conversions better or worse?
How much does the performance change with this commit?
Of course, according to the users demands, this project is expandable, and I’d like to implement many functionalities over this year.
Overview of the application
The brain of the application, or the back end, will be implemented using the flask microframework and deployed using Docker and docker-compose. The application will be based on the ifc-pipeline open-source project https://github.com/AECgeeks/ifc-pipeline.
An overview of how the application will be working is available on the schema below. As you can see, the workflow relies on 2 main computations (steps 3 and 4).
1. Query IfcOpenShell repository for new commits
The flask server will query the IfcOpenShell GitHub repository for new commits at a predefined rate.
2. Check whether it is stored in the database
If the commit id is not registered in the database and if it concerns IfcOpenShell C++, it will save the new commit to the database, and launch the computations.
3. Compute the IfcConvert builds
The server will build the IfcConvert executable for each OCCT version. So, there will be 2 builds per new commit.
3.5. Query the test files repository https://github.com/IfcOpenShell/files to pull new files if necessary.
4 . Compute the results
The computation involves IfcConvert conversions using the cartesian product of all the builds we have and all the files. Next, once the computations are completed, the logs will be parsed, and the results will be calculated and stored in the database.
Once the results are available, the front end can query them. A rough idea of how the application will look like is displayed below. I will use React to make things easier for the filtering and data visualization.
Next steps
As you may have guessed, the next months will consist in making a first implementation of the project, which will need the following steps in 2 parts:
Part 1
Create the missing scripts
Tie them together into a flask project
Set-up the server and deploy the application without or with very simple front-end
At this point, I’ll make the code available on Github.
Part 2
Once the server is set up, I need to:
Start to compute the builds
Request files
Compute the results
Then, I’ll implement the front-end, and the application will be available to users.
Once the application is up and running, I’d like to implement the following functionalities:
Test IfcOpenShell python recipes
Use new OSes for testing rather than only Linux
Allow users to have their own account with their own environments and files
Make the flask server as an API
I will try to post regularly about the Test environment on the OsArch forum and communicate on other media such as Twitter. Any interesting technicality will also be discussed on the IfcOpenShell blogs. Please feel free to reach out for any suggestion or question you may have about this project at johan@aecgeeks.com.
