by bernd on 5 Nov 2021, edited 16 Nov 2021
Hi there,
is there a possibility in ifcopenshell to directly get the material name of a building element easily? Similar to the great get_psets() method.
cheers Bernd
BTW: in FreeCAD we use this ... https://github.com/FreeCAD/FreeCAD/blob/916fe37a6b757e3bf6d51fb65ebc412243125d8e/src/Mod/Arch/importIFCHelper.py#L239-L257
by Moult on 6 Nov 2021
@bernd ifcopenshell.util.element.get_material(element, should_skip_usage=True or False you choose)
by bernd on 8 Nov 2021, edited 8 Nov 2021
works great. Setting the material Name works too :-)
What does the parameter "should_skip_usage" do?
by bernd on 9 Nov 2021, edited 9 Nov 2021
Just to be sure ... There is no ifcopenshell.util.element.get_layer() in https://github.com/IfcOpenShell/IfcOpenShell/blob/v0.7.0/src/ifcopenshell-python/ifcopenshell/util/element.py or is there some other short smart way to get the layer.
FreeCAD code for layer:
https://github.com/FreeCAD/FreeCAD/blob/916fe37a6b757e3bf6d51fb65ebc412243125d8e/src/Mod/Arch/importIFC.py#L404-L411
cheers bernd
by Moult on 9 Nov 2021
Sorry no layer utility. PR welcome :)
The should_skip_usage determines if you want to skip the material set usage and jump straight to the material set. Usages are per instance, so sometimes its not what you're after.
by Moult on 16 Nov 2021
+3 votes
... and we now have an ifcopenshell.util.element.get_layers()! https://github.com/IfcOpenShell/IfcOpenShell/commit/41486ba08a3ddcbd5dd40a086dd9b96ca6a3fbaa
