ply
format ascii 1.0
element vertex 2161426
property float x
property float y
property float z
property uchar intensity
property uchar red
property uchar green
property uchar blue
end_header
-4.20678 -2.78534 0.67217 213 215 219 230
-4.22023 -2.77447 0.03119 213 207 208 222
-4.22387 -2.76731 0.07319 214 206 208 220
-4.19342 -2.82999 0.03114 213 201 203 215
And then saved the file as a .ply file and imported it into Blender, it worked.
However the colours are missing, I have two questions
How can I tell if a .pts file has colour support?
Is there an easier way to import a point cloud in Blender?
When importing the .pts file in BimCollabZoom colours were also missing, I also got sent an e.57 file. I checked it's a binary file. Are the colours perhapes stored in there?
What is your main objective with using point clouds? Why Blender?
It's a very small point cloud of the entrance of a historical city hall ('gemeentehuis'), It has a lot of complex ornaments/detailing. I thought Blender would be perfect for this to model over the point cloud to produce an IFC the contractor can use in his software.
by magicalcloud_75 on 28 Nov 2021, edited 28 Nov 2021#
Because it's kind over 'redrawing' a model (overtrekken) you can use whatever you are most comfortable with. Personally i try to avoid it as much as possible. Just use the survey data. Your remodelled enity may act as 'noise'. Check out what i made with CloudCompare. Company logo and all :)
Yay this is right up my alley ! I highly recommend the CloudCompare / Point Cloud Visualizer workflow to work with laser scanner data (Sanitize PC in CC and model over PC data in Blender).
I also highly recommend the pro version of PCV addon (which I just noticed has a 2.0 version coming up with very interesting features) which is more performant and allows you to natively use a bounding box dynamic clipping object, which is life-saving when working in closed environments :
I also wish Blender "Point cloud" features would involve 3d scanner data but I don't think that's their priority. It's more geared towards fluid simulation at the moment.
It's not really an error, rather an info message saying your point cloud doesn't have normals associated with it. Not all laser stations add normals to the points, but there are tools to compute them after the fact.
The downside of not having normals is it can't be properly dynamically illuminated. But it should import correctly nonetheless ?
@duncan done ! I'd very much like to contribute to the wiki, but I'm more a Q&A kind of person, I don't really know where to start every time I open a blank wiki page. I'll try and remember to update the wiki when I see some relevant stuff.
@CadGiru I suggest you make the "paid version" a link. Please also make the GPL-2.0-only as a link to the license - you'd be surprised how the license can be buried away on some projects. If the source is not public (not a requirement of the GPL) then I'm not sure where to link to.
