Blender Procedural Topo Contours
  1. B
  2. M
    Setting the amount of slices is not the way to get this correct from a engineering point of view. Qgis has gooed tools to set interval and labels.
  3. B
    @magicalcloud_75 you are definitely right that setting the amount of slices is not the right way to go for AEC purposes but I am excited to see that it seems like creating contours will at least be fairly easy in the near future and I hope that doing it at elevation intervals rather than slices will be a trivial adjustment.
  4. D
    it's actually fairly easy in blender even without geonodes., but a bit slower. create a large plane, add array modifier and set Z constant to 1m or whatever the distance, and boolean fast intersect with landscape.
  5. G
    You can also get it real-time for visualisation purposes with a custom shader.
