by MaoZerhouni on 6 Jan 2022, edited 10 Jan 2022
I wanted to know if, in your environment, you find usecases linked to IfcPropertyListValue. Not necessarily attached to the IFCScheme, what useCases are linked to giving a property a list of values ?
The use cases I came across all should be in fact handled by other entities :
- An object can be linked to multiple document > Should be handled by IfcRelAssociates
V
by vpajic on 10 Jan 2022
Hi @MaoZerhouni - You can find this kind of concept during the construction stage of projects, whereby an architect/engineer specifies an element (non-manufacturer specific) in their design, but defines requirements where each have a range of applicable values. The contractor then has the freedom to choose a specific product as long as it adheres to these requirements.
