learning Modelling was (and still is) a very fun process. Nevertheless the rendering and Materials part is much more difficult, probably because of the lack of passion for amazing visuals, so I was hoping someone can give me a good (hopefully fast) fix.
I'm very happy with the solid view I have, there are a lot of materials and colors that could use work but the model is very usable. Nevertheless when I change to Material Preview or Rendered (i can see no difference between both), everything seems to be to white. The Red color of the section is also propagating to elements behind the cutting plan, and there is a mesh (the red one not bein cut).
I believe everything has to do with some ambient lighting setting and some funny material property in the mesh, but don't know where to look, could someone point me in the right direction please?
Ideally my solid view and rendered view should look (almost) the same but with the elements being cut.
