by Andyro on 23 Aug 2024, edited 23 Aug 2024
Is there a way to write these building physical property values into a Classification Library as are found in blenderbim/bim/schema/classifications? ie. can we append values to lines like in the Masterformat spec item: #864=IFCCLASSIFICATIONREFERENCE($,'03 31 00','Structural Concrete',#862,$,$); - to include thermal, mass, cost and other values and schedule or calculate from these values in a meaningful way? Would adding a property to the above look like this? (I'd need help w syntax as I have no idea)... #1533=IFCCLASSIFICATIONREFERENCE($,'07 21 13.19','Mineral Board Insulation',#1530,$, (‘ThermalConductivityTemperatureDerivative',$,IFCREAL(0.035),$; - where the U-value for Rockwool CB110 for example is 0.035W/mK
by brunopostle on 23 Aug 2024
@Andyro I have no experience of Classification libraries, but in principle you should be able to create an IFC file that contains just your materials with all their physical properties, shading colours etc.. in the form of IfcMaterial and related entities. Then you can use the Project Library > Custom Library feature of Bonsai to import them into any future models.
(there are some missing features here: it would be nice to be able to import a material and have it clobber any existing materials with the same name; similarly it would be nice to be able to select several materials and Ctrl-J to merge them into a single material)
by theoryshaw on 23 Aug 2024
I'm not an archicad user, but per this comment, it seems you can set the 'translator' to export Material Properties.
https://forums.buildingsmart.org/t/does-these-attributes-are-defined-by-buildingsmart-or-not/1371/7
I've reached out to Stefan to see what I am missing there. His sample is from AC23, we're at AC27 now, there may be some small differences in translator settings, I will find out tx!
+5 votes
Finally! Got it to work.
It was a 'Data Conversion' option in the ArchiCad translator, where 'Building Material Properties and Classifications' needs to be checked/selected. Then all of the values from our established templates import to BBim and can be viewed and presumably scheduled for wbLCA purposes.
+3 votes
Settings here in the IFC translator in AC:
U
by ubiquity on 10 Oct 2024
I have been struggling with how to represent walls with steel framing, external steel cladding and internal plasterboard lining in my geometry.
I understand Dion's comment that "nothing in IFC requires geometry" but I need the geometry for visual representation.
Do I represent the external cladding as a wall type and use this to construct the geometry? Alternatively, if I classify the external cladding as a class, what geometry do I use to include it in 2D/3D representations.
The same would apply to wooden frame structure with wood or cement/other sheet cladding.
Not being either an architect or an engineer this puzzles me.
by steverugi on 10 Oct 2024
hi @ubiquity
I use IfcCovering[CLADDING] for it (vertical layer)
for the frame you can use IfcMember[STUD] or [PLATE] etc.. (extruded profile)
if that may comfort you, for me too it hasn't been an easy ride, but I got used to enjoying it :)
U
Thank you for your reply and sentiment!
